kuidas saan m21d24 mootoril (2.4d) mootori märgid paikka mootori rihma vahetades.
kiiresti oleks vaja teada.
m21d24 mootori rihma märgid.
Kindel pole aga kiire googel andis sellise pildi aga kõige õigem oleks hankida autodata või leida inimene kellel see olemas on.
I pinned the flywheel through the block with a 5/16" drill bit (non-cutting side into the flywheel) to lock the crank at #1 TDC. The "O / T" mark on the harmonic balancer confirms #1 TDC b/c it lines up with the notch on the upper timing belt cover.
-I pinned the injection pump cog with a 3/8" drill bit through the lower pinning hole in the cog (~7 o'clock) and into the hole in the IP mounting bracket. (This drill bit size fit much more snuggly than the usually recommended 11/32" bit).
