e28 pidurikettad
Tartlane
e28 pidurikettad
Postitus Postitas Tartlane »
Tere, ei osand nagu mujale ka postitada ning üks lihtne ja loll küsimus jälle :D. Kas spetsialistid oskavad öelda, et kas e28 BMW-le sobivad alla e34 kettad?
redline
Postitus Postitas redline »
Ketta paksus oli vist neil erinev, aga koos e34 subbortiga sai panna küll.
Kunagi jäi kuskilt foorumist E24 pidurite (loe: samad pidurid mis E28-l)upgrade kohta silma selline kokkuvõte, ehk abiks:
What are the bolt on BMW upgrade?
Many people have started upgrading the brakes on their E24s. Well here is a list of BMW brakes and the cars they come off of, which fit the E24.
Remember you may need larger wheels and tires if you increase the size of your brakes. Also remember that the pads are different then the stock
E24 brakes.
Front
E32(all) The calipers are single piston. Part #: 34 11 1 160 363/364
To be used with 302mm diameter x 28mm thick rotors. Part #: 34 11 1 159 896
E28 M5/ E24 M6 The calipers are 4 piston. Part #: 34 11 2 225 002/003
To be used with 300mm diameter x 30mm thick rotors. Part #: 34 11 2 225 007
Or used with 302mm diameter x 28mm thick rotors. Part #: 34 11 1 159 896
Not suggested but still fits
E34 525i/535i/540i/530i The calipers are single piston. Part #: 34 11 1 160 367/368
To be used with 302mm diameter x 22mm thick rotors. Part #: 34 11 1 160 936
E34 M5 The calipers are single piston. Part #: 34 11 2 226 407/408
To be used with 315mm diameter x 28mm thick rotors. Part #: 34 11 2 226 385
E34 M5 Euro(Nurburgring brakes) No info available as of yet.
No info available as of yet, but they do bolt on.
E31 up to 8/93 The calipers are single piston. Part #: 34 11 1 160 325/326
To be used with 324mm diameter x 30mm thick rotors. Part #: 34 11 1 159 895
E31 after 8/93 The calipers are four piston. Part #: 34 11 1 161 177/178
To be used with 324mm diameter x 30mm thick rotors. Part #: 34 11 1 161 086
Rear
E34 535i/525i The calipers are single piston. Part #: 34 21 1 157 557/558
To be used with 300mm diameter x 10mm thick solid rotors. Part #: 34 21 1 162 305
E34 540i/M5 The calipers are single piston. Part #: 34 21 1 159 657/658
To be used with 300mm diameter x 20mm thick vented rotors. Part #: 34 21 1 165 265
E32 740i/750iL The calipers are single piston. Part #: 34 21 1 160 399/400
To be used with carrier. Part #: 34 21 1 160 384
Here are a list of stages of braking upgrades. The amount of benifit you recieve from the upgrade is mainly dependant on the pads and rotors you use.
Stage 1: E32 fronts
Stage 2: E28 M5/ E24 M6 fronts
Stage 3: E32 fronts, E34 solid rears
Stage 4: E28 M5/ E24 M6 fronts, E34 solid rears
Stage 5: E32 fronts, E34/E32 vented rears
Stage 6: E28 M5/ E24 M6 fronts, E34/E32 vented rears
Stage 7: E34 M5 all around
Stage 8: E31 front, E34/E32 vented rears
Stage 9: E34 Euro(Nurburgring brakes)
